  • Open the .osm file with a text editor
  • CTRL-F "VariableRefrigerantFlow" ... should point you to the OpenStudio VRF object(s)
  • Take note of the class, e.g. CoilCoolingDXVariableRefrigerantFlow
  • Look up the class in the SDK object index (CTRL-F "VariableRefrigerantFlow" will yield 8 objects)
  • Whatever VRF attribute can be edited via OpenStudio (e.g. performance curves) would be listed.
  • As not all OpenStudio VRF object definitions hold COP, search in the generated IDF (and cross-reference)
