The BCL measure prototypes are not intended to represent the DOE/PNNL .idf prototypes, as explained in the openstudio-standards documentation. The BCL measure will be deprecated and replaced with a measure to create "typical" buildings to help clarify the distinction.
The method you use depends on your use case:
  • Code comparisons and determinations under the Energy Policy Act -> use the DOE/PNNL .idf prototypes
  • All other use cases -> use the typical building models / OpenStudio measure to create typical buildings
  • case: - Code comparisons and determinations under the Energy Policy Act -> use the DOE/PNNL .idf prototypes
  • prototypes - All other use cases -> use the typical building models / OpenStudio measure to create typical buildingsbuildings.
The BCL measure prototypes are not intended to represent the DOE/PNNL .idf prototypes, as explained in the openstudio-standards documentationdocumention. The BCL measure will be deprecated and replaced with a measure to create "typical" buildings to help clarify the distinction.
The method you use depends on your use case: - Code comparisons and determinations under the Energy Policy Act -> use the DOE/PNNL .idf prototypes - All other use cases -> use the typical building models / OpenStudio measure to create typical buildings.
