The ResStock and ComStock End Use Savings Shapes datasets (here and here) are large repositories of energy models and simulation results. ResStock uses ~550,000 simulations to represent the U.S. residential housing stock while ComStock uses ~350,000 simulations to represent the U.S. commercial building stock. Each has about 10 efficiency measures/packages that are evaluated on top of the baseline simulations.
The ResStock and ComStock End Use Savings Shapes datasets (here and here) are large repositories of energy models and simulation results. ResStock uses ~550,000 simulations to represent the U.S. residential housing stock while ComStock uses ~350,000 simulations to represent the U.S. U.S> commercial building stock. Each has about 10 efficiency measures/packages that are evaluated on top of the baseline simulations.
The ResStock and ComStock End Use Savings Shapes datasets (here and here) are large repositories of energy models and simulation results. ResStock uses ~550,000 simulations to represent the U.S. residential housing stock while ComStock uses ~350,000 ~315,000 simulations to represent the U.S> commercial building stock. Each has about 10 efficiency measures/packages that are evaluated on top of the baseline simulations.
