If you go to the SketchUp Menu Extensions->OpenStudio->Preferences you will see an option to set the "OpenStudio Root Directory". Assuming you installed OpenStudio Application v1.6.0 to the default location, you should set this to "C:/openstudioapplication-1.6.0" and restart SketchUp. After that the OpenStudio SketchUp Plug-in will be configured to use OpenStudio Application 1.6.0.
