In BEopt 2.8, you would have to split your parametric into two cases, each with 128 points.
In BEopt 3, there is a setting where all output files for larger parametric and optimization cases can be preserved:
There are no known issues running parametric analysis in BEopt 3. Use BEopt 3.0.1 if you are not already, as it includes a number of bugfixes. If you still have an issue, please provide your project file via e.g. a Google Drive or Dropbox link.
