You should check in either the eQ_Lib.dat, bdllib.dat, or usrlib.dat in your eQuest installation. I think any material/construction is described in one of those files and are imported into eQuest at runtime. The default materials and constructions are in bdllib.dat file. I don't know offhand if there is a way to view that information within eQuest itself, maybe someone else can answer that better.
