Another easy way, if you are only interested in a radiant heating system, is to use the ZoneHVAC:Baseboard:RadiantConvective:Electric object. This requires no further design objects or node definitions, however you need to specify how much radiation will reach which surface (up to 20 are possible). It will not introduce new air, but note that it will influence the humidity due to heating up the air. You can set the radiant fraction as desired (0-1). If set to 0 it acts like an IdealAirLoadsSystem without, outdoor air method and humidity control.
