Hi Grainne,
If a stat is not available you should enter the information on the Statistics tab by hand. The stat file is automatically generated by the Hourly weather data translation process. https://designbuilder.co.uk/helpv7.2/#Add_new_hourly_weather_data.htm
The Edit/Translate Hourly Weather Data dialog can be accessed from the Tools menu and can be used to process hourly weather data. You may wish to do this for various reasons:
- Convert EnergyPlus epw data to be compatible with DesignBuilder day of week results for daily, hourly and sub-hourly output (set the year to 2002).
- Translate weather data in other formats to the epw format so that it can be used in DesignBuilder.
- Generating modified weather data sets for investigating climate change scenarios. https://designbuilder.co.uk/helpv7.2/#_Edit_hourly_weather_data.htm
