When heat recovery mode is NOT active, the total terminal unit capacity should equal the VRF total capacity. When heat recovery mode IS active, the operating mode is either cooling or heating. The terminal units operating in the active mode should equal the VRF (active mode) total capacity. If this is not the case please provide the input file.
