thus, I can't connect to the server via PAT. I have got a message, "Pod unschedulable", on the Google Cloud Console in which it seems like the cluster was not created with enough resources.
My 2 cents, is it possible there is some limit got hit from GCP?
Could you try to restart it from the scractch (i.e. delete the node and renew one from GCP) and see how it works again.
I suspect there is some resource(maybe disk) used up in your node/box/server.
Thanks,
