You also may want to take a look at the PerformancePrecisionTradeoffs object. The documentation for it is here
https://bigladdersoftware.com/epx/docs/23-1/input-output-reference/group-simulation-parameters.html#performanceprecisiontradeoffs
I would encourage you to try different options when running a short time period and see the impact on energy consumption. After you have gained confidence, run the entire year using those options.
