If you use an asterisk (*) as the Key Value, the output will include all possible E+ objects (Key Values) that the output variable pertains to. Then you can filter down to a single E+ object if that's your interest.
Alternatively, you can search for the output variable in the E+ Input/Output Reference documentation and see what E+ object it applies to.
