The short answer is yes. The long answer is that "energy transfer" data is organized on system, zone, facility, building, heating, or cooling meters.
Energy transfer meters refer to air or water energy transfer. The electric meters report electrical energy use. Meters used in a simulation are listed in the meter file (mdd). Each meter is described in more detail in the meter definition file (mtd). At the top of the mtd file is a list of all energy and electricity report variables and on which meters those variables are reported. For example one energy transfer variable shows the multiple meters where this energy data is stored:
 Meters for 306,SPACE1-1:Zone Air System Sensible Heating Energy [J]
  OnMeter=EnergyTransfer:Facility [J]
  OnMeter=EnergyTransfer:Building [J]
  OnMeter=EnergyTransfer:Zone:SPACE1-1 [J]
  OnMeter=Heating:EnergyTransfer [J]
  OnMeter=Heating:EnergyTransfer:Zone:SPACE1-1 [J]
In the above example, the Zone Air System Sensible Heating Energy is included on meter=Heating:EnergyTransfer as well as four other meters. One could infer that all zones would be included on the same heating energy transfer meter and finding this specific meter in the mtd shows that the Heating:EnergyTransfer meter contains information for each zone.
 For Meter=Heating:EnergyTransfer [J], ResourceType=EnergyTransfer, EndUse=Heating, contents are:
  PLENUM-1:Zone Air System Sensible Heating Energy
  SPACE2-1:Zone Air System Sensible Heating Energy
  SPACE3-1:Zone Air System Sensible Heating Energy
  SPACE4-1:Zone Air System Sensible Heating Energy
  SPACE5-1:Zone Air System Sensible Heating Energy
All energy data contained on a single meter is summarized at the bottom of the file. In this example, the energy transfer data for SPACE1-1:
 For Meter=EnergyTransfer:Zone:SPACE1-1 [J], ResourceType=EnergyTransfer, Group=Zone, contents are:
  SPACE1-1:Zone Air System Sensible Cooling Energy
 For Meter=Heating:EnergyTransfer:Zone:SPACE1-1 [J], ResourceType=EnergyTransfer, EndUse=Heating, Group=Zone, contents are:
 For Meter=Cooling:EnergyTransfer:Zone:SPACE1-1 [J], ResourceType=EnergyTransfer, EndUse=Cooling, Group=Zone, contents are:
From the Input Output Reference document:
"Zone Air System Sensible Heating Energy [J]
This output variable represents the sensible heating energy in Joules that is actually
supplied by the system to that zone for the timestep reported. This is the sensible
heating rate multiplied by the simulation timestep. This is calculated and reported
from the Correct step in the Zone Predictor-Corrector module. This field is not
multiplied by zone or group multipliers. Zone Air System Sensible Heating (and
Cooling) Energy (and Rate) all report the heating or cooling delivered by the HVAC
system to a zone. These values are calculated by multiplying the supply air mass
flow rate by the difference between the supply air temperature and the zone air
temperature. This does not always indicate the operation of heating or cooling coils.
For example, cooling will be reported if the supply air is cooled due to the introduction
of outside air, even if all coils are off. Note that these variables are calculated at the
system timestep. When reported at the detailed reporting frequency, these variables
will never show heating and cooling both in the same system timestep. If reported at
a frequency less than Detailed (for example, Hourly) values may appear in both the
heating and cooling variable for the same hour if the system cooled the zone for part
of the reporting period and heated the zone for another part of the reporting period.
Zone Air System Sensible Cooling Energy [J]
This output variable represents the sensible cooling energy in Joules that is actually
cooling rate multiplied by the simulation timestep. This is calculated and reported
multiplied by zone or group multipliers."
Energy transfer meters refer to air or water energy transfer. The electric meters report electrical energy use. Meters used in a simulation are or listed in the meter file (mdd). Each meter is described in more detail in the meter definition file (mtd). At the top of the mtd file is a list of all energy and electricity report variables and on which meters those variables are reported. For example one energy transfer variable shows the multiple meters where this energy data is stored:
Energy transfer meters refer to air or water energy transfer. The electric meters report electrical energy use. Meters used in a simulation or listed in the meter file (mdd). Each meter is described in more detail in the meter definition file (mtd). At the top of the mtd file is a list of all energy and electricity report variables and on which meters those variables are reported. For example one energy transfer variable shows the multiple meters where this energy data is stored:
"Zone Zone Air System Sensible Heating Energy [J]
system timestep. When reported at the detailed "detailed" reporting frequency, these variables
a frequency less than Detailed "Detailed" (for example, Hourly) values may appear in both the
multipliers.
Energy transfer meters refer to air or water energy transfer. The electric meters report electrical energy use. Meters used in a simulation or listed in the meter file (mdd). Each meter is described in more detail in the meter definition file (mtd). At the top of the mtd this file is a list of all energy and electricity report variables and on which meters those variables are reported. For example one energy transfer variable shows the multiple meters where this energy data is stored:
system timestep. When reported at the "detailed" reporting frequency, these variables
a frequency less than "Detailed" (for example, Hourly) values may appear in both the
Energy transfer meters refer to air or water energy transfer. The electric meters report electrical energy use. Each meter is described in the meter definition file (mtd). At the top of this file is a list of all energy and electricity report variables and on which meters those variables are reported. For example one energy transfer variable shows the multiple meters where this energy data is stored:
supplied actually supplied
sensible heating rate multiplied multiplied
reported from the Correct step in the Zone Zone
Predictor-Corrector module. . This field is not
not multiplied by zone or group multipliers. Zone Air System Sensible Heating (and
Air
System Sensible Heating (and Cooling) Energy (and Rate) all report the heating or cooling cooling
HVAC system to a zone. These values are calculated by multiplying the supply supply
air mass
mass flow rate by the difference between the supply air temperature and the zone air
coils. For example, example,
introduction of outside air, even even
the system timestep. When When
variable will never show heating and and
at a frequency less than "Detailed" "Detailed"
the heating and cooling variable for the the
part of the reporting period and heated the the
actually supplied by by
sensible cooling rate multiplied by by
