While the add variable and add meter measures only allow you can add a single meter, you can add multiple instances of these to your workflow to add in more than one meter.
If you have a specific set of outputs you frequently like to look at you can also hard code them all into one measure. You would basically loop through the code adding a different string in each time. For reference here is a link to the add output variable and the add meter measures.
Many outputs can be directly added from the output variables tab (icon is an "X") without the use of a measure. We don't have an interface for meters.
