If you are using CBECC-Com you can also find them in a folder that is part of the installation package. In your main documents folder it should install a folder called "CBECC-Com 2013 Data" and down the following path you'll find the appendices in spreadsheet form Documents\CBECC-Com 2013 Data\Documents\ACM
