I think what you are after is naturally complicated and there is not really an easy way to report or interpret such information. I would suggest plotting these two output variables together as an x-y scatter plot.
Surface Inside Face Convection Heat Gain Rate per Area vs. Surface Heat Storage Rate per Area
The time delay issue is tricky here so you might try requesting daily frequency as well as hourly. Or process the hourly data into something like an 8-hour moving average.
