If you only need Electricity:HVAC, you can put it in the meter file with this line:
Output:Meter:MeterFileOnly,Electricity:HVAC,runperiod;
In the RVI file, make sure each parts are on separate lines, like this:
eplusout.mtr
eplusout.csv
Electricity:HVAC
Output:SQLite and Output:Diagnostics may not be necessary in the parametric run.
