You should make sure you're creating or connecting everything that EnergyPlus needs to have the Generator:MicroTurbine operate in the model. See, for instance, the part:
The ElectricLoadCenter:Generators and ElectricLoadCenter:Distribution objects are used to define the availability and control of all electric generators included in the simulation.
The ElectricLoadCenter:Generators and ElectricLoadCenter:Distribution objects are used to define the availability and control of all electric generators included in the simulation.simulation."
