If you want to add the heat to the supply side of plant loop, you could use DistrictHeating. Just set the nominal capacity to the constant source you want and setup the operation scheme and setpoints so it runs all the time.
If you want to add the heat to the demand side of a plant loop you could use EMS with a user-defined plant component, input object PlantComponent:UserDefined.
