If you look in the .mtd file you will see the meter details which contains what you are looking for. It is documented at:
http://bigladdersoftware.com/epx/docs/8-3/output-details-and-examples/index.html
And click on the link for "eplusout.mtd"
(The link directly to that portion did not seem to work when I tried it).
It is described as:
The meter details file consists of two parts:
For report variables that are on meters, it shows all the meters that the report variable is on. In the following example, “Meters for” , is shown and then the meters that accumulate the value of that variable as a “meter”.
For each meter, the report variables that make up that meter are shown. In the following example, “For Meter=” , “contents are:” and then each variable that occurs on that “meter” are shown.
I think what you want is in the second half. Unfortunately, the list of output variables that are contained in Electricity:Facility is usually very long, often dozens or hundreds of variables.
To include them in the ESO file, each one would need an Output:Variable object.
