For building rotations in OpenStudio, take a look at this measure on the BCL.
To alter window characteristics like shading coefficient, take a look at this measure on the BCL.
These measures are best applied using OpenStudio's Parametric Analysis Tool (PAT) so you don't have to manually create each design alternative. Learn more about using PAT to evaluate different design alternatives here.
These measures are best applied using OpenStudio's Parametric Analysis Tool (PAT) so you don't have to manually create each design alternative. Learn more about using PAT to evaluate different design alternatives here.alternative.
For building rotations in OpenStudio, take a look at this measure on the BCL.https://bcl.nrel.gov/node/37877.
To alter window characteristics like shading coefficient, take a look at this measure on the BCL.https://bcl.nrel.gov/node/37876.
These measures are best applied using OpenStudio's Parametric Analysis Tool (PAT) so you don't have to manually create each design alternative.(PAT).
