Q1 CheckConvexity issue: Exposed floor "88ADEF" is certainly non-convex. The Shading Calculation Method is PolygonClipping (default), while your Solar Distribution choice is FullExteriorWithReflections. These should not trigger non-convex warnings IMHO. Maybe linked to this open issue. If you really want to get to the bottom of this, break up the floor surface into 3x distinct rectangular surfaces.
image description.
Q2 Mismatched interzone surfaces & areas: You have a first set of 3x problematic surfaces (stripped-down IDF inputs):
B5C9E7,              !- Name
Wall,                !- Surface Type
U_2D01,              !- Outside Boundary Condition Object
6.057, 6.630,  6.600
6.057, 6.630,  3.400
6.057, 9.880,  3.400
6.057, 9.880,  6.600
U_2D01,              !- Name
B5C9E7,              !- Outside Boundary Condition Object
6.057, 8.130, 6.600
6.057, 8.130, 3.400
6.057, 6.630, 3.400
6.057, 6.630, 6.600
1F431C,              !- Name
6.057, 9.880, 6.600
6.057, 9.880, 3.400
6.057, 8.130, 3.400
6.057, 8.130, 6.600
... mismatched vertices + "B5C9E7" is referenced 2x. It looks like it should be broken into 2x wall surfaces: one facing "U_2D01", the other facing "1F431C".
Another pair of problematic surfaces:
7F857D,                  !- Name
C05674,                  !- Outside Boundary Condition Object
 6.057, 6.630, 6.600
 6.057, 6.630, 3.400
11.057, 6.630, 3.400
11.057, 6.630, 6.600
C05674,                  !- Name
7F857D,                  !- Outside Boundary Condition Object
 3.057, 6.630, 3.400
 3.057, 6.630, 6.600
... vertices don't line up. I suspect a need to break up "C05674", and an orphaned/missing surface somewhere.
Q3 Mismatched construction layers with interzone surfaces:
559937,                          !- Name
Ceiling,                         !- Surface Type
DasarAtap,                       !- Construction Name
C680B1,                          !- Outside Boundary Condition Object
C680B1,                          !- Name
Floor,                           !- Surface Type
Interior Floor,                  !- Construction Name
559937,                          !- Outside Boundary Condition Object
DasarAtap,                       !- Name
ID GypsumBoard 12 mm;            !- Outside Layer
Interior Floor,                  !- Name
ID GypsumBoard 12 mm,            !- Outside Layer
F05 Ceiling air space resistance,!- Layer 2
M15 120mm heavyweight concrete,  !- Layer 3
ID Plaster-Wall,                 !- Layer 4
ID Ceramic;                      !- Layer 5
... constructions of coupled interzone surfaces need to match (same layers, yet in reverse order if asymmetrical).
