I got the same message as @Denis Bourgeois. After fixing that (when not running using EP-Launch), by running ExpandObjects.exe and then changing expanded.idf to in.idf, the file ran successfully with these results. If you are running the file and not getting these results you may have a memory issue.
Program Version,EnergyPlus, Version 23.1.0-a116efebd3, YMD=2023.04.26 15:25,
   ** Warning ** Version: in IDF="22.2" not the same as expected="23.1"
   ************* Beginning Zone Sizing Calculations
   ** Warning ** Weather file location will be used rather than entered (IDF) Location object.
   **   ~~~   ** ..Location object=SITE 1
   **   ~~~   ** ..Weather File Location=Abuenas.Ardeche.Meridionale.AP AR FRA SRC-TMYx WMO#=075700
   **   ~~~   ** ..due to location differences, Latitude difference=[44.54] degrees, Longitude difference=[4.37] degrees.
   **   ~~~   ** ..Time Zone difference=[1.0] hour(s), Elevation difference=[28000.00] percent, [280.00] meters.
   ** Warning ** ProcessScheduleInput: Schedule:Constant="ALWAYS OFF DISCRETE", Blank Schedule Type Limits Name input -- will not be validated.
   ** Warning ** WindowMaterial:Blind="FIXEDWESTBLINDS", Slat Angles/Widths
   **   ~~~   ** Slat Width [2.00E-002] is less than Slat Separation [6.00E-002].
   **   ~~~   ** This will allow direct beam to be transmitted when Slat angle = 0.
   ** Warning ** GetHTSurfaceData: Surfaces with interface to Ground found but no "Ground Temperatures" were input.
   **   ~~~   ** Found first in surface=ROOM_1EDE771E..FACE_8242890E
   **   ~~~   ** Defaults, constant throughout the year of (18.0) will be used.
   ** Warning ** CheckUsedConstructions: There are 16 nominally unused constructions in input.
   **   ~~~   ** For explicit details on each unused construction, use Output:Diagnostics,DisplayExtraWarnings;
   ** Warning ** GetShadowingInput: The shading transmittance for shading devices changes throughout the year. Choose DetailedSkyDiffuseModeling in the ShadowCalculation object to remove this warning.
   **   ~~~   ** Simulation has been reset to use DetailedSkyDiffuseModeling. Simulation continues.
   **   ~~~   ** Better accuracy may be gained by setting the Shading Calculation Update Frequency to 1 in the ShadowCalculation object.
   ** Warning ** DetermineShadowingCombinations: There are 2 surfaces which are receiving surfaces and are non-convex.
   **   ~~~   ** ...Shadowing values may be inaccurate. Check .shd report file for more surface shading details
   **   ~~~   ** ...Add Output:Diagnostics,DisplayExtraWarnings; to see individual warnings for each surface.
   ** Severe  ** DetermineShadowingCombinations: There are 2 surfaces which are casting surfaces and are non-convex.
   **   ~~~   ** ...Add Output:Diagnostics,DisplayExtraWarnings; to see individual severes for each surface.
   ** Warning ** DeterminePolygonOverlap: Too many figures [>15000]  detected in an overlap calculation. Use Output:Diagnostics,DisplayExtraWarnings; for more details.
   ** Warning ** GetSimpleAirModelInputs: ZoneInfiltration:DesignFlowRate="ROOM_44AC0377_SPACE EN-RESIDENTIAL::DETACHEDHOUSE_INFILTRATION 1", Design Flow Rate Calculation Method specifies Flow Rate per Exterior Surface Area, but Exterior Surface Area = 0.  0 Infiltration will result.
   ** Warning ** GetSimpleAirModelInputs: ZoneInfiltration:DesignFlowRate="ROOM_8561C570_SPACE EN-RESIDENTIAL::DETACHEDHOUSE_INFILTRATION 1", Design Flow Rate Calculation Method specifies Flow Rate per Exterior Surface Area, but Exterior Surface Area = 0.  0 Infiltration will result.
   ** Warning ** GetSimpleAirModelInputs: ZoneInfiltration:DesignFlowRate="ROOM_2E48DDB6_SPACE EN-RESIDENTIAL::DETACHEDHOUSE_INFILTRATION 1", Design Flow Rate Calculation Method specifies Flow Rate per Exterior Surface Area, but Exterior Surface Area = 0.  0 Infiltration will result.
   ** Warning ** GetSimpleAirModelInputs: ZoneInfiltration:DesignFlowRate="ROOM_B1E4A21E_SPACE EN-RESIDENTIAL::DETACHEDHOUSE_INFILTRATION 1", Design Flow Rate Calculation Method specifies Flow Rate per Exterior Surface Area, but Exterior Surface Area = 0.  0 Infiltration will result.
   ** Warning ** Calculated design cooling load for zone=ROOM_0699BC5E is zero.
   **   ~~~   ** Check Sizing:Zone and ZoneControl:Thermostat inputs.
   ** Warning ** Calculated design heating load for zone=ROOM_0699BC5E is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_1EDE771E is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_1F720C4F is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_1F720C4F is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_2026D0CC is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_2E48DDB6 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_2E48DDB6 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_30ACC1D2 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_30ACC1D2 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_44AC0377 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_44AC0377 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_47B9D778 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_47B9D778 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_5EAB1A30 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_60BC52E3 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_60BC52E3 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_6B856D51 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_6CFF8DE8 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_76889BF8 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_76889BF8 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_8561C570 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_8561C570 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_857999E1 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_857999E1 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_A3514892 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_A3514892 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_B1E4A21E is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_B1E4A21E is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_BEB107B4 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_D77E358B is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_EFDEE8D3 is zero.
   ** Warning ** Calculated design heating load for zone=ROOM_EFDEE8D3 is zero.
   ** Warning ** Calculated design cooling load for zone=ROOM_F9E70596 is zero.
   ** Warning ** Temperature out of range [-100. to 200.] (PsyPsatFnTemp)
   **   ~~~   **  Routine=CalcPurchAirLoads, During Sizing, Environment=ABUENAS.ARDECHE.MERIDIONALE.AP HEATING DESIGN DAY 99.6% CONDNS DB, at Simulation time=01/21 24:00 - 24:10
   **   ~~~   **  Input Temperature=-154946.77
   ** Warning ** ManageSizing: For a plant sizing run, there must be at least 1 Sizing:Plant object input. SimulationControl Plant Sizing option ignored.
   ************* Testing Individual Branch Integrity
   ************* All Branches passed integrity testing
   ************* Testing Individual Supply Air Path Integrity
   ************* All Supply Air Paths passed integrity testing
   ************* Testing Individual Return Air Path Integrity
   ************* All Return Air Paths passed integrity testing
   ************* No node connection errors were found.
   ************* Beginning Simulation
   ** Warning ** The resource referenced by LifeCycleCost:UsePriceEscalation= "U.S. AVG  COMMERCIAL-ELECTRICITY" has no energy cost.
   **   ~~~   ** ... It is likely that the wrong resource is used. The resource should match the meter used in Utility:Tariff.
   ** Warning ** The resource referenced by LifeCycleCost:UsePriceEscalation= "U.S. AVG  COMMERCIAL-DISTILLATE OIL" has no energy cost.
   ** Warning ** The resource referenced by LifeCycleCost:UsePriceEscalation= "U.S. AVG  COMMERCIAL-RESIDUAL OIL" has no energy cost.
   ** Warning ** The resource referenced by LifeCycleCost:UsePriceEscalation= "U.S. AVG  COMMERCIAL-NATURAL GAS" has no energy cost.
   ** Warning ** The resource referenced by LifeCycleCost:UsePriceEscalation= "U.S. AVG  COMMERCIAL-COAL" has no energy cost.
   ************* Simulation Error Summary *************
   ** Warning ** The following Report Variables were requested but not generated -- check.rdd file
   **   ~~~   ** Either the IDF did not contain these elements, the variable name is misspelled,
   **   ~~~   ** or the requested variable is an advanced output which requires Output : Diagnostics, DisplayAdvancedReportVariables;
   ************* Key=*, VarName=AFN ZONE INFILTRATION SENSIBLE HEAT GAIN ENERGY, Frequency=Hourly
   ************* Key=*, VarName=CHILLER HEATER SYSTEM HEATING ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=COOLING COIL ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=COOLING COIL WATER HEATING ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=COOLING TOWER FAN ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=DISTRICT COOLING CHILLED WATER ENERGY, Frequency=Hourly
   ************* Key=*, VarName=DISTRICT HEATING HOT WATER ENERGY, Frequency=Hourly
   ************* Key=*, VarName=EVAPORATIVE COOLER ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=FAN ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=HEATING COIL ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=HEATING COIL NATURALGAS ENERGY, Frequency=Hourly
   ************* Key=*, VarName=AFN ZONE INFILTRATION SENSIBLE HEAT LOSS ENERGY, Frequency=Hourly
   ************* Key=*, VarName=HEATING COIL TOTAL HEATING ENERGY, Frequency=Hourly
   ************* Key=*, VarName=HOT_WATER_LOOP_CENTRAL_AIR_SOURCE_HEAT_PUMP ELECTRICITY CONSUMPTION, Frequency=Hourly
   ************* Key=*, VarName=HUMIDIFIER ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=PUMP ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=SURFACE CONSTRUCTION INDEX, Frequency=Hourly
   ************* Key=*, VarName=AFN ZONE VENTILATION SENSIBLE HEAT GAIN ENERGY, Frequency=Hourly
   ************* Key=*, VarName=VRF HEAT PUMP COOLING ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=VRF HEAT PUMP CRANKCASE HEATER ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=VRF HEAT PUMP DEFROST ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=VRF HEAT PUMP HEATING ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=WATER HEATER ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=WATER HEATER NATURALGAS ENERGY, Frequency=Hourly
   ************* Key=*, VarName=WATER USE EQUIPMENT HEATING ENERGY, Frequency=Hourly
   ************* Key=*, VarName=ZONE GAS EQUIPMENT NATURALGAS ENERGY, Frequency=Hourly
   ************* Key=*, VarName=AFN ZONE VENTILATION SENSIBLE HEAT LOSS ENERGY, Frequency=Hourly
   ************* Key=*, VarName=BASEBOARD ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=ZONE OTHER EQUIPMENT LOST HEAT ENERGY, Frequency=Hourly
   ************* Key=*, VarName=ZONE OTHER EQUIPMENT TOTAL HEATING ENERGY, Frequency=Hourly
   ************* Key=*, VarName=ZONE VRF AIR TERMINAL COOLING ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=ZONE VRF AIR TERMINAL HEATING ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=BOILER ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=BOILER NATURALGAS ENERGY, Frequency=Hourly
   ************* Key=*, VarName=CHILLER ELECTRICITY ENERGY, Frequency=Hourly
   ************* Key=*, VarName=CHILLER HEATER SYSTEM COOLING ELECTRICITY ENERGY, Frequency=Hourly
   ************* There are 3 unused schedules in input.
   ************* There are 3 unused week schedules in input.
   ************* There are 16 unused day schedules in input.
   ************* Use Output:Diagnostics,DisplayUnusedSchedules; to see them.
   ************* ===== Recurring Error Summary =====
   ************* The following recurring error messages occurred.
   *************  ** Warning ** Temperature out of range [-100. to 200.] (PsyPsatFnTemp)
   *************  **   ~~~   **   This error occurred 9 total times;
   *************  **   ~~~   **   during Warmup 0 times;
   *************  **   ~~~   **   during Sizing 9 times.
   *************  **   ~~~   **   Max=-338.096588 C  Min=-154946.773438 C
   ************* ===== Final Error Summary =====
   ************* The following error categories occurred.  Consider correcting or noting.
   ************* Nominally Unused Constructions
   ************* ..The nominally unused constructions warning is provided to alert you to potential conditions that can cause
   ************* ..extra time during simulation. Each construction is calculated by the algorithm indicated in the HeatBalanceAlgorithm
   ************* ..object. You may remove the constructions indicated (when you use the DisplayExtraWarnings option).
   ************* EnergyPlus Warmup Error Summary. During Warmup: 0 Warning; 0 Severe Errors.
   ************* EnergyPlus Sizing Error Summary. During Sizing: 46 Warning; 0 Severe Errors.
   ************* EnergyPlus Completed Successfully-- 65 Warning; 2 Severe Errors; Elapsed Time=00hr 07min 24.06sec
