Failed to launch altogether, not halfway through. An excerpt of the generated "eplusout.err" file (when running the IDF with either EPW file):
** Severe ** GroundHeatTransfer:* objects [...] not supported directly by EnergyPlus.
** ~~~ ** You must run the ExpandObjects program on this input.
As mentioned elsewhere (e.g. here and here), you need to first run the Basement preprocessor program.
** Severe ** GroundHeatTransfer:* objects found [...] not supported directly by EnergyPlus.
Failed to launch altogether, not halfway through. An excerpt of the generated "eplusout.err" file (when running the IDF with either EPW file):files):
As mentioned elsewhere (e.g. here and here), you need to first run the Basement preprocessor program.program.
