Here's a 3D rendering of Zone "KM WC LT2" (with a few coordinates).
"KM WC LT2" has 12x surfaces in the IDF - there should only be 11x:
  • 7x walls
  • 2x ceilings
  • 2x floors
Wall "97F56C" looks to be the intruder (in purple). It's facing Outdoors, but that's beside the point. I have not verified other surfaces/zones in the IDF. I suggest you first fix geometry issues like this one. This may fix other issues downstream (i.e. many calculations require valid volumes/areas).
  • 7x walls
  • 2x ceilings
  • 2x floors
Wall "97F56C" looks to be the intruder (in purple). It's facing Outdoors, but that's beside the point. I have not verified other surfaces/zones in the IDF. I suggest you first fix geometry issues like this one. This may fix other issues downstream (i.e. many calculations require valid volumes/areas).surfaces/zones.
