You may have two approaches;
1) You can make a typical air-loop with no heating and cooling coils, or
2) Air loop with heating and cooling coils but setting their availability to zero, meaning coils wont work at all even though they are present in the .idf or .osm file. (See screenshot below). You have to select a schedule which will have a value of 0 throughout the day.
See this THIS for a detailed answer by Annie.
I think you can also select a temperature set-point high enough for cooling that it does not trigger HVAC system. you can apply same idea for heating season.
Availability schedule
Hope this will help.
2) Air loop with heating and cooling coils but setting their availability to zero, meaning coils wont work at all even though they are present in the .idf or .osm file. (See screenshot below). You have to select a schedule which will have a value of 0 throughout the day.file.
