The answers above are correct, but I wanted to mention an alternative method under development. This repo contains OS measure development work to reproduce the DOE reference buildings. The workflow pulls data definitions from a spreadsheet to automate generation of the model. The approach (specifically the spreadsheet content) can be extended to create other models, e.g. baselines compliant with other standards. The resulting measure set will be formally released around September, but you can inspect the code in its current state in the repo.
