If you leave it as an EPW file, the weather converter assumes that everything is okay. It will convert some things, such as dew point or relative humidity if those values are "missing" but not, I think, the solar values.
You will need to input it as a "custom" with a "definitions" file to get it to effect a split in solar. Here is a link to the StdEPWDefFormat.def and here is the content:
&wthdata
NumInHour=1
InputFileType='CUSTOM'
InFormat='DELIMITED'
DataElements=year,month,day,hour,minute,datasource,Dry_Bulb_Temperature,Dew_Point_Temperature,Relative_Humidity,Atmospheric_Pressure,Extraterrestrial_Horizontal_Radiation,Extraterrestrial_Direct_Normal_Radiation,Horizontal_Infrared_Radiation_Intensity_from_Sky,Global_Horizontal_Radiation,Direct_Normal_Radiation,Diffuse_Horizontal_Radiation,Global_Horizontal_Illuminance,Direct_Normal_Illuminance,Diffuse_Horizontal_Illuminance,Zenith_Luminance,Wind_Direction,Wind_Speed,Total_Sky_Cover,Opaque_Sky_Cover,Visibility,Ceiling_Height,Present_Weather_Observation,Present_Weather_Codes,Precipitable_Water,Aerosol_Optical_Depth,Snow_Depth,Days_Since_Last_Snow,Albedo,Liquid_Precipitation_Depth,Liquid_Precipitation_Quantity
DataMissingValues=99999,99,99,99,99,,999,999,999,999999,9999,9999,9999,9999,9999,9999,999900,999900,999900,9999,999,999,99,99,9999,99999,9,999999999,999,0.999,999,99,999,999,99
DataUnits='x','x','x','x','x','x','C','C','%','Pa','Wh/m2','Wh/m2','Wh/m2','Wh/m2','Wh/m2','Wh/m2','lux','lux','lux','Cd/m2','deg','m/s','tenths','tenths','km','m','x','x','mm','{.001}','cm','x','{.01}','mm','hr'
DataConversionFactors=1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1,1
DelimiterChar=','
&miscdata
Comments1='Standard EPW Custom def format'
SourceData='EPW'
&datacontrol
NumRecordsToSkip=8
MaxNumRecordsToRead=8784
MissingWindDirAction=RANDOM
! Other options on datacontrol:
! MissingDataAction
! MissingWindDirAction
! MissingWindDirValue
! MissingOpaqueSkyCoverAction
! MissingOpaqueSkyCoverValue
! MaxWindSpeed
! MaxDirectSolar
! MaxDiffuseSolar
! MaxIlluminanceValue
! GenerateSolarRadiationWarnings
! GenerateIlluminanceWarnings
! MinDBTempByMonth
! MaxDBTempByMonth
! MinDPTempByMonth
! MaxDPTempByMonth
Linda
FIBPSA, FASHRAE https://climate.onebuilding.org - free repository of climate data for building simulation Climate.onebuilding is a FREE service not supported by any outside organization or government agency.
You will need to input it as a "custom" with a "definitions" file to get it to effect a split in solar. Here I would attach it here but the unmet hours will only apparently allow picture files. I will try to send it as a private message.
Can't send private messages -- here is a link to the StdEPWDefFormat.defStdEPWDefFormat.def and here is the content:
&wthdata
NumInHour=1
DelimiterChar=','
&miscdata
SourceData='EPW'
&datacontrol
NumRecordsToSkip=8
! MissingDataAction
! MaxWindSpeed
! MaxDirectSolar
! MaxDiffuseSolar
! MinDBTempByMonth
! MaxDBTempByMonth
! MinDPTempByMonth
! MaxDPTempByMonth
Linda
You will need to input it as a "custom" with a "definitions" file to get it to effect a split in solar. I would attach it here but the unmet hours will only apparently allow picture files. I will try to send it as a private message.
Can't send private messages -- here is it a dropbox link to the StdEPWDefFormat.def and here is the content:standard EPW format https://www.dropbox.com/s/959stzgl009ea3o/StdEPWDefFormat.def?dl=0
&wthdata
NumInHour=1
DelimiterChar=','
&miscdata
SourceData='EPW'
&datacontrol
NumRecordsToSkip=8
! MissingDataAction
! MaxWindSpeed
! MaxDirectSolar
! MaxDiffuseSolar
! MinDBTempByMonth
! MaxDBTempByMonth
! MinDPTempByMonth
! MaxDPTempByMonth
Linda
Can't send private messages -- here it a dropbox link to the standard EPW format https://www.dropbox.com/s/959stzgl009ea3o/StdEPWDefFormat.def?dl=0
Linda
