Thanks for sharing your models.
For M1, when viewing in Euclid an entire SouthGroundwallBasement wall appears to be missing and if you look you will se that the coordinates for NorthGroundwallBasement are exactly the same, so it is actually overlaying that wall. If you fix the coordinates it should work.
For M2, you zoned the ground floor and the upper floor in the same zone called "entire house" but you are mirroring the floor between the levels (even though they are in the same zone), one called Interior Ceiling_Rev and GroundfloorCeilingintouchwithUpperfloor which is appropriate if they were in different zones. Try making the upper and ground floors as two separate zones and it should work. If you want to leave that as a single zone, just get rid of the surfaces between them.
I hope those changes help.
