That is great to hear as this is a needed feature for labs where zones are negatively pressurized and receive make-up air from other zones. I could see this living at the zone level in the GUI as I most often use this in conjunction with the Zone Exhaust Fan object.
That is great to hear as this is a needed feature for labs where zones are negatively pressurized and receive make-up air from other zones. I could see this living at the zone level in the GUI as I will most often use this be used in conjunction with the Zone Exhaust Fan object.object which is currently access at the zone level as well.
That is great to hear as this is a needed feature for labs where zones are negatively pressurized and receive make-up air from other zones. I could see this living at the zone level in the GUI as I it will most often be used in conjunction with the Zone Exhaust Fan object which is currently access at the zone level as well.
