I have run the DOE Prototype measure and then the ChangeBuildingLocation measure after that. You do have to provide an EPW, DDY, and STAT file for the alternate location. The Stat file is used by ChangeBuildingLocation to get the ClimateZone and water main temperatures. You should run the Prototype measure for the same climate zone as. your custom weather file so there are reasonable representations of system efficiencies, which will be based on the original weather file.
