I wanted to create the Schedules programatically using only user arguments supplied to my measure. I eventually opted for a different approach, instead of using user argument to create the custom schedules and then get the schedule values via sensors, I use the arguments directly in my EMS program combined with conditional statements, for example :
IF (CurrentTime >= #{cs}) && (CurrentTime <= #{ce})
SET #{charging_auth.name} = 1
ELSE
SET #{charging_auth.name} = 0
ENDIF
or
IF (Month == #{drm}) && (DayOfMonth == #{drd}) && (CurrentTime>= #{drst})&& (CurrentTime<=#{dret})
SET DR_flag = 1
SET #{atc_charging_auth.name} = 0
SET #{atc_discharging_auth.name} = 1
ELSE
SET DR_flag = 0
ENDIF
It does the trick
