Hello @khadidja20 its an interesting thermal performance, the temperature increases because the effect of insulation and enclosure, maybe the key of the increase could be the air number changes, if the idf building envelope does not have configure the air number changes then does not have air renovation and the humidity increases the inner heat. Check the configuration for air changes renovation. Greetings.
