Not really an answer to the Original Post. But I have the same exact Question/Issue .
And I wonder if those two measures are supported in a gbXML workflow, rather than via Sketchup?
I don't use Sketchup and am setting up Geometry from imported gbXML.
I've run the Openstudio measures in this order
Add Daylight Sensor at the Center of Spaces with a Specified Space Type Assigned ( I assign them to every space that is of Office-OpenOffice) and this measure seems to complete and adds sensors to all spaces of this type.)
Radiance Daylighting Measure
Running the second Measure it fails with this error:
Info: epw2wea "C:\Users\Alistair\AppData\Local\Temp\osmodel-1674087925-1\resources\files\GBR_Birmingham.035340_IWEC.epw" wx\in.wea
[13:29:37.875656 ERROR] Found error in state 'os_measures' with message [":/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with message Runner error :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb failed with No such file or directory @ rb_sysopen - numeric/merged_space.map, eval:443:in `initialize'
eval:443:in `open'
eval:443:in `open'
C:/Users/Alistair/AppData/Local/Temp/osmodel-1674087925-1/resources/measures/RadianceMeasure/measure.rb:2449:in `run'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:517:in `apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:in `block in apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `each_index'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in `apply_measures'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in `perform'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:in `step'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in `run'
:/openstudio_cli.rb:1173:in `execute'
:/openstudio_cli.rb:803:in `execute'
:/openstudio_cli.rb:1972:in `<main>'
eval: 188:in `eval'
eval: 188:in `require_embedded_absolute'
eval: 173:in `block in require_embedded'
eval: 167:in `each'
eval: 167:in `require_embedded'
eval: 126:in `require'
eval: 3:in `<main>' in :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:545:in `rescue in apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:505:in `apply_measure'
eval: 188:in `eval'
eval: 167:in `each'
eval: 3:in `<main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:654:in `rescue in apply_measure'
:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:651:in `apply_measure'
eval: 188:in `eval'
eval: 167:in `each'
eval: 3:in `<main>'
Failed.
Simulation failed to run, with exit code 1
Thank you
And I wonder if those two measures are supported in a gbXML workflow, rather workflow,rather than via Sketchup?sketchup?
Add
1/Add
Daylight Sensor at the Center of Spaces with a Specified Space Type Assigned ( IRadiance
error:
eval:443:in `open'
eval:443:in `open'
eval: 188:in `eval'
eval: 167:in `each'
eval: 188:in `eval'
eval: 167:in `each'
eval: 188:in `eval'
eval: 167:in `each'
eval: 3:in `<main>'
initialize'\neval:443:inopen'\neval:443:in open'\nC:/Users/Alistair/AppData/Local/Temp/osmodel-1674087925-1/resources/measures/RadianceMeasure/measure.rb:2449:inrun'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:517:in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:inblock in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1173:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1972:in
'\neval:188:in eval'\neval:188:inrequire_embedded_absolute'\neval:173:in block in require_embedded'\neval:167:ineach'\neval:167:in require_embedded'\neval:126:inrequire'\neval:3:in <main>' in :/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:545:inrescue in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:505:in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:inblock in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1173:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1972:in
'\neval:188:in eval'\neval:188:inrequire_embedded_absolute'\neval:173:in block in require_embedded'\neval:167:ineach'\neval:167:in require_embedded'\neval:126:inrequire'\neval:3:in <main>'::/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:654:inrescue in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:651:in apply_measure'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:114:inblock in apply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:in each_index'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/util/measure.rb:67:inapply_measures'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/jobs/run_os_measures.rb:70:in perform'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:291:instep'\n:/ruby/2.7.0/gems/openstudio-workflow-2.3.1/lib/openstudio/workflow/run.rb:233:in run'\n:/openstudio_cli.rb:1173:inexecute'\n:/openstudio_cli.rb:803:in execute'\n:/openstudio_cli.rb:1972:in
'\neval:188:in eval'\neval:188:inrequire_embedded_absolute'\neval:173:in block in require_embedded'\neval:167:ineach'\neval:167:in require_embedded'\neval:126:inrequire'\neval:3:in `
Failed.
Thank you
