You will be able to "save as" if you change the "Project Name" field in the "Project" tab, "General" section.
Alternatively, you can also download the .JSON file to your computer, then upload that file to restore a state. This is also the current method for sharing projects between users.
A related tip: you can be running Sketchbox in two (or more) web browser tabs at the same time. This is currently the easiest way to visualize and compare results for different HVAC concepts.
