Currently when a measure writer updates a measure on BCL, and you have that measure, there is no alterting system of an update. If you however use the "find measures" dialog, it should show you the update and allow you to download it, assuming that the new update doesn't require a newer version of OpenStudio than you have. See this post for more information.
By the way, we are working on another update to this that should be done in a month or so. It may replace the standard report currently in OpenStudio. If I can find link to screenshot of that from another post I'll update this.
