You will need to create some EMS objects before EnergyPlus will generate an EDD file for you. All you need is a single EMS object. I'd suggest adding something simple to your IDF, such as:
  EnergyManagementSystem:GlobalVariable,
    Test_variable;            !- Erl Variable 1 Name
That should be enough to generate the EDD file.
You will need to create some EMS objects before EnergyPlus will generate an EDD file for you. All you need is a single EMS object. I'd suggest adding something simple to your IDF, simple, such as:
