Are you planning to run one representative model or 85 separate models? OpenStudio doesn't have a residential building type template...yet.
If you haven't already you may want to take a look at BEopt which also runs EnergyPlus and offers a quick and easy way to generate an IDF as well as easy to use parametric and optimization options for residential buildings.
Currently OpenStudio does not model solar thermal although there is a measure for solar electric. BEopt can model both solar thermal and PV. In either case you should be able to alter the resulting IDF for your purposes.
Currently Neither BEopt or OpenStudio does not currently model solar thermal although there is a measure for solar electric. electric in OpenStudio and BEopt can model both solar thermal and PV. has a PV option. In either case you should be able to alter the resulting IDF for your purposes.
Are you planning to run one representative model or 85 separate models? OpenStudio doesn't have a residential building type template...yet.template.
Neither BEopt or OpenStudio currently model solar thermal although there is a measure for solar electric in OpenStudio and BEopt has a PV option. OpenStudio. In either case you should be able to alter the resulting IDF for your purposes.
Are you planning to run one representative model or 85 separate models? OpenStudio doesn't have a residential building type template.models?
Neither BEopt or OpenStudio currently model solar thermal although there is a measure for solar electric in OpenStudio. In either case you should be able to alter the resulting IDF for your purposes.
OpenStudio does not currently model solar thermal although there is a measure for solar electric. If you haven't already you may want to take a look at BEopt which also runs EnergyPlus and offers a quick and easy way to generate an IDF as well as easy to use parametric and optimization options for residential buildings.
Neither BEopt or OpenStudio currently model options, but doesn't support solar thermal although there is a measure for solar electric in OpenStudio. either. In either case you should be able to alter the resulting IDF for your purposes.
