I´ve solved the problem after seeing this post: https://unmethours.com/question/3110/openstudio-160-unable-to-run-energyplus-82/ My computer was running a 32-bits Windows 7 so at first I installed both SketchUp and OpenStudio 32-bits versions. This was the configuration giving me problems. It seems that the built-in EnergyPlus that is installed together with OpenStudio caused the problem, either because it was looking for a non-existing location in the hard disk or because it was a 64-bits version of the program. Anyway, I had to make a complete backup, install a new 64-bits Windows 8 and then re-install SketchUp and OpenStudio (64-bits). Now it is working fine.
