The VirtualPulse project has made a similar web application that runs measures, though they are not using ASP.NET. I can't really comment on why your system isn't working, it's possible some additional security settings are enabled in the production environment? You should look through your log files and see what you can find.
The VirtualPulse VirtualPulse project has made a similar web application that runs measures, though they are not using ASP.NET. I can't really comment on why your system isn't working, it's possible some additional security settings are enabled in the production environment? You should look through your log files and see what you can find.
