I did finally get back around to working on this problem and managed to get it to work. I ended up building most of the AFN in an OS measure and doing clean up work in an E+ measure. The E+ measure mainly added the extra AFN nodes between the fan and the coils and the unitary output. It is very loop specific but our residential loops are created the same way each time. I imagine with a lot more logic it could be extended to a generalized unitary loop.
