Here's another way to solve it: If you select "DisplayExtraWarnings" from the "Output:Diagnostics" object, you should see some warnings similar to this:
* Warning * GetVertices: Distance between two vertices < .01, possibly coincident. for Surface=C1000000_C24, in Zone=FC-1-1
* ~~~ * Vertex [3]=(98.38,70.59,3.05)
* ~~~ * Vertex [2]=(98.38,70.60,3.05)
* ~~~ * Cannot Drop Vertex [3]; Number of Surface Sides at minimum. This surface is now a degenerate surface.
Further down you will see your severe error that just counts up the number of degenerate surfaces. This is the only error you would see if you didn't use Output:Diagnostics, DisplayExtraWarnings:
* Severe * GetSurfaceData: There are 12 degenerate surfaces; Degenerate surfaces are those with number of sides < 3.
* ~~~ * These surfaces should be deleted.
It's not necessarily surfaces that have <3 sides initially. All of these surfaces had 4 points initially, and when combing through the model, also show up with 4 sides.
Surface=C1000000_C24,Surface=C1000000_C24, in Zone=FC-1-1
Further down you will see your severe error that just counts up the number of degenerate surfaces. This is the only error you would see if you didn't use Output:Diagnostics, DisplayExtraWarnings:surfaces:
DistanceDistance between two vertices < .01,possiblypossibly coincident. forSurface=C1000000_C24,Surface=C1000000_C24, in Zone=FC-1-1 * ~~~ * Vertex [3]=(98.38,70.59,3.05) * ~~~
* ~~~ * Vertex [3]=(98.38,70.59,3.05)* Vertex [2]=(98.38,70.60,3.05)
* ~~~* ~~~ * Cannot Drop Vertex
[3];[3]; Number of Surface Sides atminimum.minimum. This surface is now a degenerate surface.
Further down you will see your severe error that just counts up the number of degenerate surfaces:
DegenerateDegenerate surfaces are those with number of sides < 3.* ~~~ * These surfaces should be deleted.
* ~~~ * These
* Warning * GetVertices: Distance between two vertices < .01, possibly coincident. for Surface=C1000000_C24, in Zone=FC-1-1 * ~~~ * Vertex [3]=(98.38,70.59,3.05) * ~~~
* Vertex [2]=(98.38,70.60,3.05) * ~~~ * Cannot Drop Vertex [3]; Number of Surface Sides at minimum. This surface is now a degenerate surface.
* Severe * GetSurfaceData: There are 12 degenerate surfaces; Degenerate surfaces are those with number of sides < 3. * ~~~ * These surfaces should be deleted.
