I'm in the process of adding most of the AirflowNetwork group into OpenStudio, but I'm afraid it won't be completed until later this summer. I am aiming for making it into 1.9, which will be out in September.
It would be possible to add in the necessary objects via a measure, but doing so will require some care (as well as knowledge of AirflowNetwork and the OpenStudio model). If you have a pretty good command of the OpenStudio model, it should be fairly doable.
