OpenStudio doesn't directly support airflow network. You would have to add that as an EnergyPlus measure. I don't think anyone has written this yet. If you did have this measure you could parameterize it with PAT.
For an example of an EnergyPlus measure see the simple PV measure. In the most basic form an EnergyPlus measure can be a large block of IDF text with variables setup where desired.
