Hi Southeast, I've encountered a similar problem. For a different issue (vertex mismatch error), I was advised here to try using the "Surface Matching Diagnostic" measure which is now also found on the BCL thankfully.
While that post was for a different issue, it has also resolved the weird slashed lines issue I encountered later. Using that instead resulted in proper matching. I realize this is a bit late but hopefully this help if you're still encountering the issue. In my case, I encountered fatal errors and couldn't run a simulation on the model at all.
