For reference, the OpenStudio Application and the SketchUp Plugin are now maintained by the OpenStudio Coalition, but the OpenStudio Software Development Kit (SDK) is still developed by NREL and other DOE labs. I suggest you get the measure from the Building Component Library (BCL), and make sure to check for updates. If you are using the OpenStudio Application the BCL is accessible from within the application.
