On the Run Tab, click the "Verbose Output" checkbox at the top and try to see if you can get more information.
Also, try to see if you can run the E+ executable itself. Open your Terminal and type:
/Applications/OpenStudioApplication1.4.0/EnergyPlus/energyplus --help
