An ideal air system is not mean to be a realistic piece of equipment. It's often used to calculate the building's heating and cooling loads or is used when the HVAC equipment is not known. It has a constant year-round COP of 1, though I believe you can specify a heating or cooling efficiency for it using the EnvironmentalImpactFactors object -- see the District Heating Efficiency and District Cooling COP fields.
If you want to model an air conditioning system, you can add a DX coil object to your model. Unlike an ideal air system, air conditioners and heat pumps will have COPs that vary throughout the year based on (primarily) outdoor temperature.
An ideal air system is not mean to be a realistic piece of equipment. It's often used to calculate the building's heating and cooling loads or is used when the HVAC equipment is not known. It has a constant year-round COP of 1, though I believe you can specify a heating or cooling efficiency for it using the EnvironmentalImpactFactors object -- see the District Heating Efficiency and District Cooling COP fields.object.
