See the link and steps below to create an EnergyPlus Measure that will allow you to change the output file formats and units.
Change Output File Formats And Units Measure
- Copy the contents of
measure.rb - Create a new measure from the Measures tab in OpenStudio
- Name the measure in the dialog box
- Measure Type: EnergyPlus Measure
- Taxonomy: Reporting, QAQC
- Create measure and open for editing
- Open the newly created measure.rb template file
- Replace the template code with the code from the file above or simply replace the measure.rb file entirely.
- Save the measure.rb file and add it to your OSM as an always run EnergyPlus measure
The measure allows the user to select options for output file formats and unit conversions for the EnergyPlus object OutputControl:Table:Style.
After a simulation the results in IP units will be available from Results Summary > Reports > EnergyPlus Results. The output files in IP units will be available from osm directory > run > EnergyPlus-0.
Note: Using this measure will prevent OpenStudio from displaying the built-in IP reporting measure (Issue #283).
Note: Using this measure will prevent OpenStudio from displaying the built-in IP reporting measure end use bar graph and data after a simulation (Issue #283).
Note: Using this measure will prevent OpenStudio from displaying the end use bar graph and data after a simulation (Issue #283).
See the link and steps below to create for an EnergyPlus Measure that will allow you I wrote to change the output file formats and units.format and units. It allows one to select the fields for the OutputControl:Table:Style object.
See the link below for an EnergyPlus Measure I wrote to change the output format and units. It allows one to select the fields for the OutputControl:Table:Style object.OutputControl:Table:Style
Change Output File Formats Format And Units Measure
boxbox - e.g. "Change Output File Format And Units" - Measure Type: EnergyPlus Measure
Change Output Format And Units Measure
- Name the measure in the dialog box - e.g. "Change Output
FileFormat And Units" - Measure Type: EnergyPlus Measure
See the link below @Mel - here's the code for an EnergyPlus Measure measure that will do what you need. It creates the OutputControl:Table:Style object that allows you to select additional output files and change the units to IP.
Change Output Format And Units Measurehad to give the file a fake extension to post it here, but it should be renamed measure.rb after you download it. Follow these steps to create your own copy of the measure:
"Change"Customize OutputFormat And Units"Tables" - Measure Type: EnergyPlus Measure
file - Replace the template file and replace the code with the code from the
fileaboveorfile OR simply replace themeasure.rbfile entirely. - Save the measure.rb file and add it to your
OSM as an always run EnergyPlus measureOSM
Note: Using using this measure will prevent OpenStudio from displaying the end use bar graph and data after a simulation (Issue #283).
@Mel - here's the code for an EnergyPlus measure that will do what you need. It creates the OutputControl:Table:Style object that allows you to select additional output files and change the units to IP.
I had to give the file a fake extension to post it here, but it should be renamed measure.rb after you download it. Follow these steps to create your own copy of the measure:
- Name the measure in the dialog box - e.g. "Customize Output Tables"
- Open the newly created measure.rb template file and replace the code with the code from the above file OR simply replace the file entirely.
Note: using this measure will prevent prevent OpenStudio from displaying the end use bar graph and data after a simulation. From the Results Summary tab select EnergyPlus Results from the Reports menu which should allow you to view the eplustbl.htm file in IP units from within your OSM.
