You are experiencing a limitation for what EnergyPlus objects can be used to contain various coils and fans on the supply branch of a central air system. This limitation is shown in the first table of the Unitary Equipment Group documentation of the Input Output Reference.
If you are seeing this severe error, it is likely because you are assigning the water-to-air heat pump cooling/heating coils that you want to use directly to the Branch
object. Seeing the vertical columns for these coils in the table, that is not allowed (no "X" for the first row labeled AirLoop HVAC Main Branch
). Instead, you would look for a unitary option that DOES have an "X" in it's row:
AirLoopHVAC:UnitaryHeatPump:WaterToAir
object (meant specifically to model a water-to-air heat pump)AirLoopHVAC:UnitarySystem
object (the most flexible unitary system that can contain virtually every coil and fan object available in EnergyPlus)
